What's the best connection from DVD Recorder to TV?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Eyeball, Sep 1, 2004.
  1. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Hi...
    I have a Philips 9986 and would like to know what the best connection is to my XS32 for picture and sound.
    Any info would be great. I haven't got an amp yet but will get one soon (if this makes any difference).
    Thanks,
    S
  2. dude1971
    dude1971
    Hi Eyeball
    What do you mean mate? Are you asking about Scart or S-video or what is the best cable to use?
    Regards
    The Dude
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    RGB Scart
  4. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Sorry...should have explained. I have 3 scart connection (2xRGB) and a component connection. Which should I use to get best picture and sound quality?
  5. Kevo
    Kevo
    Aug 23, 2001
    5,409
    Manchester
    +151
    The 'Usual Order' is....
    (Best first)
    DVI (one for the near future and it's high def variant)
    Componet
    RGB SCART
    S-Video (SCART or mini-din)
    Composite (SCART or phono)
  6. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Thanks Kevo.
    My 9986 has a DVI adaptor. Does the Tosh xs32 have a DVI connector?
    Sorry, prolly a dum question but thought it's worth a try. Haven't got the tosh yet so don't know what's behind it, but it's on it's way.
    Cheers,
    S
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Component is probably going to be the best way hook up the Toshiba RDXS32 with your TV although it depends how good your screen is at handling it. RGB Scart is the second best choice and would be better if you end up having problems with component. Whatever way you connect ensure you buy good quality cables!
  8. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Ok, thanks. Will look into this.
    :thumbsup:
  9. dude1971
    dude1971
