What's the BEST connection between a Pioneer and Denon
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Sep 16, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,002
    Crayford
    +218
    Hi Guys,
    What is the BEST connection between a PIONEER 868 AViS DVD player and a DENON AVR 3805 home cinema receiver?
    Are the I-Link and Denon-Link compatible? Thanks.
    Thanks,
    M.J.
  2. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    me thinks not compatible, soundwise you would have to use a coaxial. if you havent bought the Denon yet wait for Pio 2014. It will feature i-link
  3. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    Definitely incompatible. I think Denon's version is a custom link, whereas Pioneers iLink is a standard format (I could be wrong).
    I know for sure that they do not work together though.
    Sapkans suggestion is the way to go I think.
  4. MJeeves
    MJeeves
    Feb 15, 2001
    4,002
    Crayford
    +218
    I was probably gonna go for the DENON AVR 3805 and then upgrade to a DENON 5910 DVD Player (or a DENON HD-DVD player) when that comes out next year. What do you think?
  5. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
