whats the best cable to run from dvd player to av amp
SLIM
Joined
Jan 1, 2004
Messages
1,364
Reaction score
17
Points
323
Age
45
Hi guys ok what the best way for me to run my dvd player to my AV amp @ the moment i have it useing a Optical Cable but i can all so use a coaxil cable what one would be the best thanks
For shorter runs a coaxial sounds best but for longer (say 3m + ) a optical is the only option.
OK SO coaxial IS THE WAY TO GO FOR LIKE 1.0M
IMHO yes. I have both types and the coax sounds better to me and thats the important factor :D
Personaly I think there will be so little difference that any will just be percieved instead of real.
The data rate is so low, cable length is so short and its usualy buffered etc to remove jutter than neither will be much difference.
At least with optical you've electicaly isolated the equipment from each other.
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
