Whats the best 4 - 5Mega Pixel camera out there?
Discussion in 'Photography Forums' started by Ninjaman, Oct 30, 2003.
  1. Ninjaman
    Ninjaman
    Aug 15, 2003
    226
    London, United Kingdom
    Had the Kodak Easyshare digital camera LS443 4M pixel, comes with a dock and 32Mb internal memory.
    But unforturnately it has packed in, and going back to Jessops today. I took out extra insurance so it should be a problem.
    First the Lens protective shutter went, now when i switch it on the motor refuses to bring out the lens and the camera cant be switched on at all, it makes a horrible grinding noise. Other than that the build quality is not that good, and good night photo requires a photographic degree, it doesnt transfer images throug to the dock to my windows 98 OS ( contrary to the manual), it doesnt save any settings even if you just change photo mode i.e. night, dalight, landscape without switching the camera off.
    I have heard the that Canon and Konica does have new good ones.
    Any other suggestion.
    ps. i need to try a way to get off those outrageous pixs off the internal memory before i take it in.
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    How much do you want to spend?
  3. Ninjaman
    Ninjaman
    Aug 15, 2003
    226
    maximum £500, but could go a bit further
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    www.dpreview.com is a good place to look for advice but £500 will get you into the realms of the Canon Powershot G5 which is well thought of. I'd also look at Nikon & Fuji's offerings. I've never been a Sony fan but they seem to be gaining a following.
    ... What outrageous images?
  5. Brian110507
    Brian110507
    I would very highly recommend the Konica KD-400Z, I am very happy with mine. I believe the 500Z is also available now but I not used one of those.
  6. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  7. alfablue
    alfablue
    Aug 16, 2002
    287
    19
    i can reccomend the Nikon 5700
    handles like an slr, solid all metal build, has a ttl viefinder (though its an lcd) good lens, good pictures, very useful swivel lcd (though smaller than some) helps a lot when tripod mounted or held low down or above head. Has an 8x optical zoom. Takes dedicated batteries, but includes a fast charger. (Clone batteries available for £14 ish). Can have a "portrait grip" that will also take 6 x AA's as an alternative source. Good range of Nikon lens adaptors (wide and tele - wide to 28mm equivalent, tele to 400+ mm).
    available here
    http://www.bristolcameras.co.uk/coolpix-5700.htm
    for £619 with £100 cashback - goes for over £800 in jessops!
    and I can highly recommend the shop, nice people, very helpful.
    Drawbacks -
    1 needs a wired remote rather than cable release (most compact digital cameras can use neither - except Fuji S602 pro, which accepts a cable release);
    2 no focus-assist light for low light levels - thats probably the worst bit;
    3 has a hot shoe so can use an external flash (I use my Vivitar 283) - but for full control by the camera it needs to be an appropriate nikon speedlight.
    I had a fuji 6900 before - i was pleased with that but the Nikon has better zoom, more compact, 5mp rather than 3, and a few other things i like as above.
    though there is a 6mp fuji on the way soon that may be a good alternative. Fuji's are bulkier, a little flimsier, but very good for features, picture quality and value for money.
  8. acucobol
    acucobol
    Sep 7, 2003
    62
    I can highly recommend bristol cameras too. Bought 2 camears off them this year, a Minolta 7hi and a Kidak LS633. Prices are very keen and they offer webprice instore as well, so if you live nearby you can save the P&p charge.
  9. cjdawson
    cjdawson
    I have used the Minolta's DiMAGE S414 for the past couple months.
    I'm not an expert person, but here is the main features I liked:
    4x optical zoom.
    4 Mega pixels
    res: 640x480, 1280x960, 1600x1200, 2272x720
    problems:
    No Internal memory
    Very high power need (4xAA) short life with display on and flash on.
    I have not had any problems. But like having the warranties on anything like this.
  10. wokeye
    wokeye
    Apr 15, 2003
    657
    +63
    It depends on the size of camera you want really, the Canon G3 is not that small. I used to have an Olympus C-4000 zoom which is a brilliant camera that can be picked up at bargain basement prices. However like the G3 it ain't that small. I recently changed it for a Konica Revio KD410z as I wanted something smaller and did not require the manual controls of the C4000 zoom. I am really happy with this camera, just depends what you want really I guess. No point getting a camera with lots of features if you are not gonna use them!
