Whats the benefit??
Discussion in 'AV Receivers & Amplifiers' started by Desiboy501, Oct 7, 2004.
  1. Desiboy501
    Desiboy501
    Sep 26, 2004
    20
    My amp has component video inputs on it (Pioneer VSX-D814). What is the benefit of running the component video lead from DVD ---> Amp (if any?)
    I was told if I have enough inputs on my TV, which I do, its best to connect the DVD and TV directly. Everyone agree with this?
    Thanks in advance
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Yes if you have enough of the relevant connections on your TV then dont bother using the amp's connections.
  3. galewis1
    galewis1
    Apr 11, 2004
    354
    Peterborough
    +4
    From a 'purists' point of you, I'd probably agree, but many, I'm sure, would probably agree that getting your receiver to handle video as well as audio switching is such a convenience that it's worth the minimal dedrigation to signal quality.
    As you can see from my signature, I don't buy really cheap stuff (I like to aim for the mid market), I have tried both direct connections to my display and receiver switching, and I can honestly say that it makes sod all difference to my eyes at least. Best advice, as always, "Suck it... and see".
    I look at it this way.... If throughput switching was such as compromise, the likes of Meridian, TAG and, to a lesser extent, Arcam, wouldn't compromise their kit with the option to do so in the first place.
    Just mt 2p's worth...
    \gary
  4. Lostinapc
    Lostinapc
    if your amp only supports composite it (the yellow lead) but you can connect dvd to tv via scart is that not better? as you can send it rgb then
  5. astirling
    astirling
    Oct 1, 2004
    1,997
    113
    Dunfermline
    +719
    Yeah. By a country mile. But he's talking about a component connection rather than a composite one.
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,484
    Rainham Essex
    +2,487
    But other than a small PQ loss by going through the receiver you also have another dissadvantage - you need an extra component lead that will cost you more money. IMO you should save the cost of the extra lead and go direct from DVD to screen, unless as stated above you don't have enough inputs on the screen.
    Mark.
  7. Desiboy501
    Desiboy501
    Sep 26, 2004
    20
    Thanks for all the advice guys!! I think i've gathered its best to go direct rather than through the amp (I thought that was the case).
    Thanks :thumbsup:
