What's the absolute fastest most advanced encoder for android that can use Amlogic S912 hardware encoder?
Apparently its supposed to support h264 h265 1080p60 hardware encode?
I need to simply boost the volume on my Weird Science movie in Dolby Digital 5.1. I have to set my receiver to nearly max volume to hear it clearly wheras other movies need 35% and its good.
next010
It would be a lot easier to just apply audio gain to the DD 5.1 track using PC software.
Download this software, drag and drop in the movie.
  • deselect copy on the audio track but leave it enabled on video
  • set codec AC3 (Dolby)
  • set sampling = same
  • set channels = same
  • set kbits = 640
Audio filters
  • gain = try increasing to this to make it louder
  • auto gain = may not do much.
Try creating multiple copies with different gain levels to find one your happy with.
Under file select a directory and it will spit out the copy with altered audio.
Thanks bro I opted for Handbrake on the PC did 10 gain on ac3 and it worked well.
Just in case I need an advanced media encoder on android, do you have any suggestions? That allows selection of AC3 audio & bitrate & etc.
next010
Android isn't a desktop operating system, so I doubt its video editors go into that level of detail, try cyberlinks product as they exist on PC desktop too but I cant think of anything else.
Samsung HW-S60A + LG SP8YA soundbar & KEF LS50 Wireless II Reviews: Movie & TV Show News & Reviews
