Whats newer philips 9617 or 9527
matrixsc
Can anyone tell me which one of these tv's are newer? And is there a big difference between both of them?.
Thanks.
rct
9527 is newer. They are identical in spec. apart from 9617 has Dolby Digital, 9527 only Dolby Surround.
9617 (32") is fitted with a Panasonic Quintrix F Tube and 28" with either Quintrix F or Philips Cybertube. 9527 - all sizes can have either a Quintrix F Tube or a Philips Cybertube.
one happy 32" 9617 (Quintrix F) owner here :D
matrixsc
Thanks for your reply.I have a amp thats gives me dolby digital and dts so i'm guessing if the picture on both are the same then the 9725 is the better bet for me then??.Was looking at the Panasonic TX-32PB50.Which would you think is better??
astonbilla
Doesn't the 9617 have pixel plus and the other doesn't?
rct
matrixsc,
Yeah, as you have a separates system I'd go for the 9527.
I'd avoid the Panasonic PB50 as
1. Many have reported problems with it like buzzing. and
2. it has built in DD and dts which would be a waste for you!
Pixel+ really is pretty amazing... just see it for yourself!
Samsung QN800B 8K TV Review
