Whats my TV worth?
Discussion in 'TVs' started by 9761, Jul 14, 2005.
  1. 9761
    9761
    May 16, 2005
    499
    Sorry I didnt no what forums to put this in.
    Currently the only of a lovely Toshiba 32ZP48P TV. Its only 1 month Old! and Im now thinking wherever should I have gone with a LCD HDTV TV.
    So im asking how much is it worth?
    It comes with the remote, manual, 11 months of warranty, speakers and the shelf/stand. There is no damage to it, has only been wiped down with dry cloth so NO cleaner stuff has been put on the TV. I have the box with the speakers but I do not have the box that the TV came in.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,563
    In a secret location with Jennifer Lawrence
    +7,366
    Quick search on the net brings up a price of £750 new. All depends if the warranty is transferrable first off. I guess a second hand price thats only a month old would be maybe £600/£650. But I'm just guessing really. Anything too close to the best net price and people are just going to buy brand new.
  3. 9761
    9761
    May 16, 2005
    499
    All I know is that I sent off a slip with the warranty on it :confused:
    Yes I think ive even got a Toshiba DVD player I could through in.
  4. 9761
    9761
    May 16, 2005
    499
    Does anyone else have any ideas wat the SET could be worth?
  5. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,563
    +7,366
    Could do with knowing the model of the DVD player.
  6. 9761
    9761
    May 16, 2005
    499
    Its a Toshiba SD240E which has only been used to watch the Star wars Trilogy :clap:
  7. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,563
    +7,366
    Well the toshiba can be got for about £60 brand new, so it doesn't really add to much to the package price. Maybe £650?? But it still all depends on the warranty. You have sent the slip off so the warranty is in your name. It would be an idea to find out from Toshiba if it is transferrable.
  8. nig28
    nig28
    If you have a reciept, it makes no difference whose name is on it.
    Its value would be dependant on transportation costs, if you deliver it and let the new owner see it working you might get £5-600, but if you want someone to collect it that price would be much reduced.
    Nigel
  9. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    Price on the net is actually £600 if the warrenty is transferable I would say you may be able to sell it for £500 inc delivery if it isnt then you really need to knock at least another £50 off of it. Looking at ebay new ones are going for £480 to £550 (plus £60 delivery)
