What's more important - Receiver or Speakers?
Discussion in 'AV Receivers & Amplifiers' started by Rasczak, Dec 28, 2002.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    I am on the verge of purchasing a surround sound system. Having searched through the posts I can see what the preferred Receivers are at each price range but I'm unsure on how best to spend the budget. I have around £1500 to spend on Receiver, Speakers and Sub. Should I be aiming to spend around 50% of this on the receiver and the rest on the speakers or go for expensive speakers and a cheaper receiver?
    Can anyone offer any advice? Cheers
  2. Ivor_Monkey
    Ivor_Monkey
    Dec 12, 2002
    87
    I'm no expert, but I would say with a budget of £1,500, you should put about £800 aside for amp/rec (denon 3803?) and £700 for 5 speakers (and forget about the sub for now).
    PS Does your budget include cables? If not, that could be another £100.
  3. Daneel
    Daneel
    Dec 5, 2002
    2,833
    68
    London
    +8
    If you are buying 5 speakers plus a sub, I would say £500 for reciever, £1000 for speakers. Just my opinion.
  4. dts_boy
    dts_boy
    Nov 26, 2001
    2,587
    Manchester suburbs...
    +178
    yeah, £1000 for speakers is about right. try something like the ae evo3b speaker sysytem with a yamaha/denon 2803. works out at around £1400 and will leave you £100 for cable, should be good for music as well as movies though!
  5. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    Depends (nice vague answer).
    If the £1500 is a once-only spend, then I'd go for £500 amp, £1000 speakers/sub.
    If you can spend more in a few months, then I'd spends a bit more on the amp, and get a sub in a few months.
    FWIW my amp cost about £500, my speakers £1200 (when the new CHT-15 arrives).
    Cable shouldn't cost the earth, my speaker and sub cable cost me about £50 for the lot.
  6. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    I'll go with Ivor..... buying a good amp means you will get the best possible out of the speakers.
    ad
  7. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    hi Rasczak
    a good system around your price range could be
    denon 3803 can be got for about £620 or so
    as for sub,you could go for the velodyne cht 10 for £320,i think check out the power buy section.
    as for speakers,how about a pear of B&w 602(s3),£300? for l/r.and 2 pairs of 601(s3)'s,£200?each,for ctr/rears,(i think the prices for the b&w's are right?).
    i would go with this reciever and sub,other members will have more ideas for the speakers.
    total cost of this set up would be £1650 approx,so if you could push another £150/200 more out of your budget you would have better options to concider.
    regards carl
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Thanks for all the replies - it's very appreciated.
