Whats going to give you better sound, Hdmi or Optical cable?
Truth
Hi just wondering been getting mixed inf, whats going to be better sound when using Onkyo receiver, HDMi or Optical cable.
Also should I use all HDMi on the receiver when playing games and movies or should I use the tv's HDMi port, any advise will be helpful.
KelvinS1965
If you want the HD soundtracks from BluRay then you have no choice but to use HDMI as optical/coax can't carry the higher bitrate, so you drop down to DVD sound quality (actually better than typical DVDs, as you get 'core DTS' @1.5mps from BluRays output via optical/coax).
