Whats DVD-9 and DVD-18
Discussion in 'Movie Forum' started by Jon Weaver, Sep 21, 2000.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    Born in Bristol but now in Newport, (for my sins)
    +717
    I have read several posts about T2 being DVD-9 and DVD-18.
    What is this?
    Is it the number of sides/layers or something else?
    How would you know which version is which?
    Any info apprecaited
  2. Guest
    DVD-9 is single sided, dual layered. DVD-18 is dual sided, dual layered. Simply put. [​IMG]
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,160
    +717
    Thanks for that... But in some ways, wouldn't it be better to get T2 on 2x DVD-9s than 1xDVD 18s.
    Although I like Double Sided disks, I always feel that they are slight more fragile and prone to damage.
    Its not like the DVD player could read both sides.. If it could, then I would see the point, but for me, I would probably be happier with 2 single sided disks..
    Thanks again
  4. Guest
    I agree. I got a DVD-18 but I would have preferred two 9s. Not just because of wear and tear, but because you would also get a cool picture on each disc just like in the cases of ID4, The Abyss, MIB, Magnolia and Fight Club. Just to name a couple. [​IMG]
    That's pretty lame Milhouse!
  5. Guest
    http://www.dv-depot.com give the the choice of either the DVD-18 version (If they have any left ?) or the 2xDVD-9 version.
    Both versions have identical content, (they are both from the same master).
    I went for the 2xDVD-9 version as the disc cover art adds an extra layer of protection, whereas double sided discs seem to get damaged more easily.
  6. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    The numbering is down to storage capacity. DVD-9 (Single Sided souble layered) is 9GB.
    DVD-18 (Double Sided Double Layered) is 18GB.
    GB is Gigabytes by the way.
    "Sh*t! I don't belive it! You... You burnt da f*ckin money!"
    Not at all against Robbie Williams (Glasgow) Ltd or companies with a similar name
