What's difference between Arcam A22 and Arcam A32?
Discussion in 'AV Receivers & Amplifiers' started by StooMonster, Jan 9, 2003.
Tags:
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Technical / performance differences, and functional ones?
    I bought my A22 and P25-3 not too long ago and wonder when this line was updated. When did Arcam replace A22 with A32?
    StooMonster
  2. Sunday Ironfoot
    Sunday Ironfoot
  3. EvilMudge
    EvilMudge
    Sunday, those are the Diva range you are looking at, the A22 and P25 are the FMJ range.
    I think the main differences were some slight tweaking for improved sound quality and a marginal increase in power output. Obviously John Dawson can tell you a lot more...
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    I've emailed Arcam support to ask them the difference, and when FMJ range was changed. And if there is an upgrade path.
    Think I bought FMJ 2x range, at about the same time FMJ 3x range came out. If so, I will not be happy with my dealer who I asked at them time if a new range was iminent.
    StooMonster
