What's compatible with Mish 734's?
Discussion in 'Home Cinema Speakers' started by grufti, May 14, 2001.
  1. grufti
    grufti
    I have a hi-fi set up with Mish 734 floorstanders. I will be getting home cinema soon, but the speakers seems to be the hardest part. Given a total budget of upto say £600, what matching centre and rears would you buy?
    Also, would i need a subwoofer, given the bass on the 734's?, if so, which one as well?
    Cheers,
    Grufti :confused:
