whats better denon 1sr or lex mc-1
Discussion in 'AV Receivers & Amplifiers' started by rory29, Jun 24, 2002.
Tags:
  1. rory29
    rory29
    Am thinking of buying either,amps aside is their much
    difference between these to processers?
    will the lex hooked up to the big rotel rmb 1095 be much
    different then the a1sr any one had any exp
    Rory.:)
  2. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    I think the Lexicon will be much better than the decoder in the Denon (although it is pretty good). You will hear a more transparant sound, with faster and cleaner steering and a less "processed" feel. Do keep in mind that the MC-1 will not do multi-channel DVD-Audio/SACD.
  3. Guest
    Another vote for the lexicon, i upgraded from a Yamaha to a Lexicon DC2(now just to a MC12, the absolute finest processor in the world in my humble opinion) and the difference was absolutely phenomenal. Lexicon all the way using Logic 7 for everything both movies and music, you won't be dissapointed i guarantee it.
    Jason
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    I had a similar decidion to make as you Rory...
    Result:- My MC1 arrives tomorrow, I'll post first impressions as soon as I set it up after work tomorrow.
    Mark.
  5. rory29
    rory29
    I currently use a denon A1D if i buy a lex i,ll have to wait
    to upgrade my amps should still sound pretty good though my
    denon?
  6. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
