Whats best for me LCD of Plasma
Discussion in 'LCD & LED LCD TVs Forum' started by P4_MAN_25, Oct 14, 2004.
Tags:
  1. P4_MAN_25
    P4_MAN_25
    Hi guys,
    I was thinking about getting an LCD TV for my new Home theatre Pc and normal tv watchin but then thought maybe i should get a Plasma, What shall i do, What are the lifespans of each, Which has the best pictures?.
    cheers
    Colin
  2. daveb975
    daveb975
    Oct 25, 2002
    4,367
    103
    London
    +375
    Depends on your requirement for size, budgt etc.
    I am currently looking for an LCD as a second TV, and most come nowhere near the quality of my Panasonic PWD6 plasma.
    The only exception is the new Sony KLV-32MRX1, which has an amazing picture - but is too expensive for a second TV!
    I am looking at the Toshiba 26WL46, which has a good picture for £900, but not as good as a decent plasma.
    In future generations, this is likely to change and LCD will become the dominant technology.
    If you want a larger screen, I would suggest checking out the 37" or 42" Panasonic plasmas, which can be had for significantly under £2k now.
    If you want a smaller screen check out 26" and 32" LCDs from Sharp, Panasonic and Toshiba (£900-£1500), but don't expect plasma beating quality.
    If you can run to £2.5k for a 32" screen, look at the Sony 32MRX1, and get the best of both worlds!
