hi guys,
some of you may have read my nightmare thread regarding my exploits with a vga cable.
well ive had enough its all going back and i need some "proper advice" please.
basically i have a lcd tv, and my choices are,
scart, yellow/white/red, and s-video.
and i have the cable that came with the premium edition of the 360, and i must say the picture with that through yellow/red/white is poor to say the least.
with it connected with them using the scart adaptor, only a very slight improvement.
so guys whats the best way to go.
ive heard my choices are simple......
RGB Advanced Scart Cable
or
XBOX 360 S-VIDEO AV CABLE
so now my questions about the s-video one,
are, the s-video is the one i know nothing about, and ive seen them online but they confuse me slightly,
they also have the yellow/red/white connectors, but have the s-video connector as well.
so do you use the 3 connectors and the s-video??
so guys which one should i now buy, because iam going bloody crazy trying to sort thsi out.
thanks for any help.
edit
1 other question i have on a separate point,
given my connections,
isn't there a way to convert the component (red/blue/green/) into either scart or dvi-d (and get the hd signal at all)
probably not but worth a thought.
or
edit
