What's Best? A freeview dvd recorder or freewview LCD Tv?
Discussion in 'LCD & LED LCD TVs Forum' started by genfranco10, Oct 18, 2005.
Tags:
  1. genfranco10
    genfranco10
    am i better off buying a dvd recorder with built in freeview (probably a sony one
    ) or a lcd tv (26", probably samsung le41rbdx) with it built in?
    What should i get a better picture with? any recomendations?
    I will buy either the dvd recorder or the lcd tv with it but don't really want to pay the extra to get both with freeview - or should i in order to get the ultimate result?
    hope someone can offer some advice, would be much appreciated. This seemed the best place to go!
    thanks
    :lease:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,830
    Somewhere in South Yorkshire
    +6,465
    It's a heck of sight easier to record Freeview if the tuner(s) are in the recorder. It means that recordings don't need the TV to be turned on (to use its tuner).
    It's somewhat easier to watch live Freeview if the tuner is in the TV (don't need the recorder to be turned on).
    DVD recorders with Freeview only have one tuner. Many PVRs (hard disc only - no DVD) have two. However, if you're buying DVD-HDD then you'll get only one. Meaning you can only watch or record ONE Freeview channel at once.
    If you have Freeview in both then you get maximum ease of use, plus you can watch one (in the TV) whilst recording another (in the recorder).
  3. mitor
    mitor
    Mar 2, 2005
    1,255
    weston super mud
    +117
  4. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    I don't know how much you're planning on spending, but personally I don't think a "plain" DVD recorder is a great idea; in that case, I'd go for Freeview in the TV.
    If you're planning on going for one of Sony's Hard-Drive & DVD recorder combi units (with dual-layer support) then definitely get that over built-in Freeview in a set.
    They're a bit more expensive than just a DVD recorder, but far more flexible, and will save you money on discs, as you will only have to burn what you actually want to keep to DVD.
  5. mitor
    mitor
    Mar 2, 2005
    1,255
    weston super mud
    +117
    yup i quite agree the freeview and HDD combo is very sensible and easy to use, with PVR boxes at around 200 quid, do you really need the DVD recorder anyway?
  6. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    It all depends on how you plan to use it really. If you're the sort of person that only watches something once and then tapes over (deletes) it, then there's no point.
    If you're the kind of person that records stuff and then wants to watch them 6 months on or whenever, having a DVD burner makes sense. (or if you want to lend stuff out to friends/family)
    My parents have just ordered the Sony RDR-HX510S, so I'll be checking that out and deciding what I want to go for myself later. (they'll be recording cable, so not having a freeview tuner isn't an issue for them) I'm not normally one for brand loyalty, but after the experience with Sony's VTX-D800U Freeview box, compared to other ones that were highly unstable/unreliable, I may pay the extra for that alone. (and having DVD recording will be a bonus)
  7. genfranco10
    genfranco10
    thanks all, really useful!
