da_murphster
Established Member
So I have to decide how to spend my 'sub budget'
I am looking at M&K in wall speakers so only looking at M&K subs.
I can buy either:
1 x V12 M&K for approx £1k
or spend more and look at:
2 x v10 subs, either side of my listening position
or for roughly the same price as this I would get the 2 x 8 inch in wall subs and separate amp.
The in wall sub would likely be to one side of my listening position
Both these options are about £500 more
What do you reckon?
For simplicity and cost I'm leaning towards the M&K V12 but don't want to miss a trick if it will sound much better with something else
I can buy either:
What do you reckon?
