Tilt mount! - wait till you see the size of this thing. The size of the carboard box made me laugh then sit down in shock. The box has clever moulded plastic handles that allow FOUR people to move it. It does look more reasonable on the wall though.
I used a standard wall mount (horizontal bar with two vertical hangers bolted to the TV) rated at 61" screen or 70Kg max. I chucked away the screws that came with the bracket and put 8 number 120mm long frame fixers into the wall just to make sure. Absolutely no problem.
I am still playing with it but the THX mode with HD looks great. SD from 3.5m away still looks softer than I was expecting but I have not hooked up my Freesat PVR yet.
One bonus is that the DVD buttons on the Panasonic remote work my new PS3 slim. Since the PS3 is Bluetooth this is obviously working via HDMI control. Totally unexpected - well done Sony and Panasonic.
