What's a well used PW6 worth?
Discussion in 'Plasma TVs' started by anderson64, Aug 9, 2004.
  1. anderson64
    anderson64
    Dec 11, 2002
    29
    Can anyone (retailers especially) give me any idea what an ex national video rental chainstore, silver 42" PW6 with second hand PA20 stand might be worth.
    We borrowed it from a local retailer to use in a show flat and had it nicked last night. So we will need to come up with a value, don't know how many hours it had on it, was a little marked around the frame and had for some reason been removed from the shop. It worked (so I was told) and had the BNC board fitted.
    Any ideas?
  2. zedzed
    zedzed
    Jul 12, 2004
    817
    Linlithgow (nr. Edinburgh)
    +13
    I'm not a retailer - but you can get these brand new with board for around the 2K mark (less on ebay if you're prepared to take a "gamble"!) - so I'd say it was probably worth somewhere around the £1,350 mark (since the frame was marked). More importantly do you know if there were any dead pixels? If so then it's value is probably less. Take a look at the richer sounds website - they sell "graded" plasmas - so you might get an idea from that.
    ZedZed
