What's a good disc cleaner?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rambo John J, Jul 5, 2001.
  1. Rambo John J
    Rambo John J
    Aug 11, 2000
    5,122
    Hanoi Hilton
    +2,232
    I'm on the hunt for something that's good and inexpensive, anyone got any suggestions?
    All gratefully recieved :)
  2. Guest
    YEah id like 2 know 2 cause, i need a cleaner!
    Miander :D
  3. Garrett
    Garrett
    Apr 21, 2001
    43,630
    2
    167
    The best thief you'll never see.
    +8,387
    Hi John thanks for the advice the other day, hope this info works for you.
    What about isoproanol alcohol (quite a mild alcohol) I have used it on CD's and LP's before with no ill effects (so far), and if you are worried, you can rinse it off afterwards with tap water then let it dry.
    Never used it on DVD's, never had call.
    :cool:
  4. Rambo John J
    Rambo John J
    Aug 11, 2000
    5,122
    Hanoi Hilton
    +2,232
    I may well give it a go.
  5. le hutch
    le hutch
    Try an spectacle cleaning cloth. Available from Sunglass Hut and suchlike they have a microfibre type thingy going on and they remove all manner of grease etc from the surface.....
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Fariy liquid is as good as anything.
    CD's are cleaned in the same way I believe.
    It's also used on vinyl.
    Personally, I just use a smidge of water on a damp, lint free cloth. They come up squeaky clean. Any smearing can come off with a cotton bud.
  7. Silver
    Silver
  8. Gary H
    Gary H
    Jul 13, 2000
    48
    +10
    There's a product called Crystal Disc.
    I've only actually used it on CDs ( my DVDs are pretty clean :) ) but it cleaned up badly skipping audio CDs that had obvious physical scratches on the disc.
    It's not cheap ( about £5 for small tube I think ) but you only need a tiny drop per disc.
