Whats a decent All-in-one to go with Tosh HD-E1
Discussion in 'Home Cinema Buying & Building' started by SGH42, Dec 24, 2006.
  1. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Any advice please for an All-in-one that will allow me to connect my Tosh HD-E1 player & Sky HD to it & output proper 5.1.
    I have a Panny SCHT855 but I can't seem to get proper 5.1 when connecting the HD-E1.
    Steve
  2. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    Sony HF1000 or SS1000 should do the job.
  3. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Can anyone else confirm that these'll work ok, do I connect via optical with these Sony's ?
    Steve
  4. leaky5
    leaky5
    Jan 3, 2003
    942
    43
    BasVegas
    +100
    It should work OK. These systems have 2 HDMI inputs and 1 output. They also have 2 optical & 1 coax inputs.
    I have the SS1000 with a Sky HD box and LG upscaler connected via these inputs.
  5. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Sounds good, Thanks for your help.
    Steve
  6. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Any other recommendations ?
    Steve
  7. marko1
    marko1
    Nov 13, 2006
    38
    +3
    What's the problem with the Panny:confused: SCHT855 is a pretty good system so perhaps worth persevering here first. Explain the problem in a little more detail regarding connections etc. and see if you can get some ideas from the members here. Could save you from having to buy a new system as the 855 should do proper 5.1. Just a thought.
  8. SGH42
    SGH42
    Aug 13, 2004
    639
    +11
    Well I'm connecting the ED1 via optical to the Panny.
    I have selected Digital Out SPDIF Bitstream in the HD-E1 audio set up but no sound comes through the Panny, I can get 2 channel sound by selecting Digital Out SPDIF PCM.
    Steve
  9. zAndy1
    zAndy1
    Nov 26, 2002
    22,878
    2
    5
    163
    +9,342
    The problem is the SCHT855 can't decode DTS using the optical input, only DD. I assume the HD-E1 is outputting DTS all the time. So the Sony system will definitely decode DTS via the optical input?
