Whats a D4 connection and where can I get a convertor?
Discussion in 'Cables & Switches' started by smithgi, Nov 12, 2004.
  1. smithgi
    smithgi
    Nov 5, 2004
    10
    I just bought a Sanyo Z2 projector ( japanese import) and I've found that my component leads will not plug in as theres no component inputs on the back, even though the manual says there is. There is , however a D4 connector marked as component input. Is there an adapter available that will allow me to use this?
    regards
    Gavin
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Do you mean a miny D sub connector with 9 pins (like the accessory input o the back of a PC)? If so this is quite common and is used on a lot of video scalers and several projectors. Go to www.keene.co.uk and give em a ring, they will be able to make you a good quality D sub to 3 female RCA adaptor for about £15.00. If not I think I may have a spair I could sell you for about a tenner, if so post a "want" on the classifieds and I will answer it :thumbsup:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,014
    The Borders
    +3,161
    smithgi
    D4 is used pretty much exclusively in Japan - your more likely to get an adapter from your projector supplier.
    I don't think I've ever seen D4 mentioned in any UK/Euro cable and connector catalogues.
    Best regards
    Joe
  4. bmcomp
    bmcomp
    Did anyone manage to source a D4 to Component cable? I have found alot of american websites that supply one with equipment they sell but wont sell just the cable!
    HELP!!!
    :lease:
    Brian
  5. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    Can't you input component over VGA on the Sanyos anyway, or is it just on the professional models like our one at work? You just need a 5 RCA (or BNC with converters) to VGA cable, just use the red, green and blue wires from this and set projector to accept component over VGA. Of course, if you normally use VGA for something else, you'll then need to use a VGA-DVI converter aswell, but I'm sure someone will have one of them going begging (was one on my desk but can't find it now!)
  6. Lycanthrope
    Lycanthrope
    Aug 29, 2005
    I've also been looking for one of these for my projector (ordered from PriceJapan.com). Unfortunately, the only one I can find is from PriceJapan. It'll cost me about $90 Australian to get a 10m Sanyo cable shipped to Melbourne. $93 for a 5m and $80 for a 1.5m audi-technica.
    I did find one (using google) from iodata.com for a Avel Linkplayer. I assume they'd work but they don't ship outside the U.S. so I couldn't even see the price.
    Let me know if you have any luck with a converter or another source.
