What would you recommend
Discussion in 'Home Cinema Speakers' started by allsounds, Mar 7, 2005.
  1. allsounds
    allsounds
    Hi - my parents own a pub which we live above, the speaker system currently comprises of a mismatch selection of four 70 w hi fi speakers, the problem we have (apart from the msimatch speakers) is that due to them being wall mounted the bass comes straight throuh the floor into our rooms which is ok until it gets late into the night and you are trying to sleep! - could you suggest a solution to the problem and also what speakers would you recommend (being on a tight budget - country pub, background music, 70w amp) using.
    thank you in advance
    Matt
  2. Douzeper
    Douzeper
    Aug 22, 2004
    190
    16
    Antrim, Northern Ireland
    Bung the ports?
    Hang carpet behind them.
