Ok so iv posted multiple questions and I'm still no closer than I was 6 months ago.
So my question is what would you do regarding subwoofer placement design and overall system?
My room is an awkward 4.28m front to back x 4.66m wide. My sofa location will be 1m off the back wall. The room is (when finished l) fully soundproofed.
So should I use my two si ht18d4 to build two individual subwoofers to go opposite corners to try and get a decent response or build a dual opposed or dual forward firing under the screen and use my ma rsw12 up back to even out the response.
By having the two drivers in one box makes the amp decision a little easier, inuke 6000 would suffice, but separate subs means I can either go 2ohm or 8 ohm each, what amp would you go for depending on each layout? £600-700 ideally less than £500.
I will be having atmos/dts x ceiling speakers (monitor audio cp range) and hopefully xtz cinema series speakers, so based on that what avr £1k max.
