What would YOU change about this 3070 pre build?
belae1k
I’ve heard negative things about pre builds... I went ahead an ordered one though as I do not have much experience building PCs (and it was the only way to get my hands on a 3070).
Primary use will be;
-Playing Call Of Duty Warzone at highest FPS possible
-Streaming call of duty to twitch
-Music Production
Here is the prebuilt PC parts list;
Case
iBUYPOWER Slate 4 Tempered Glass ARGB Gaming Case
Case Fans
Default Case Fan
Processor
Intel® Core™ i7-10700KF Processor (8x 3.80 GHz /16MB L3 Cache)
Processor Cooling
iBUYPOWER 240mm Addressable RGB Liquid Cooling System - Black - Free Upgrade to iBUYPOWER DEEPCOOL GAMERSTORM RGB 240mm CASTLE 240EX Liquid Cooler
Memory
16 GB [8 GB X2] DDR4-3000 Memory Module - Certified Major Brand Gaming Memory [Free Upgrade to 16GB DDR4-3200 XPG D41 RGB]
Video Card
NVIDIA GeForce RTX 3070 - 8GB GDDR6 (VR-Ready)
Motherboard
MSI Z490-A PRO - WiFi, ARGB Header (2), USB 3.2 Ports (1 Type-C, 3 Type-A), M.2 Slot (2)
Power Supply
700 Watt - High Power - 80 PLUS
Primary Hard Drive
1 TB WD Blue SN550 M.2 PCIe NVMe SSD -- Read: 2400MB/s; Write: 1750MB/s
Sound Card
3D Premium Surround Sound Onboard
Network Card
Onboard LAN Network (Gb or 10/100)
CARLOS
Looks to be a decent system, Only thing I would upgrade is go to 32GB of ram as you are going to be gaming and streaming on it.
Only other thing is it doesn’t state the PSU brand or model ?
Ahsoka92
What bothers me the most is that we don't know which supplier made the PSU. A cheap PSU could be the death of any PC. Other than that i would go for Ryzen instead of Intel. But right now is a good time for prebuilds because GPU/CPU availability is bad.
