What would happen if I pushed a HD signal into a Denon 1906
andrewtayloruk
Established Member
Can anyone tell me what would happen if I pushed a HD signal from my DVI port on my laptop into the component input of my Denon 1906 then from my 1906 via Component in to my standard-def TV.
Would I get no signal, or would the Denon convert it to SD.
This seems like an incredibly stupid question, but, I can't put my finger on why.
Andrew
PS I've had a long day
Dave
It would blow up like a bomb.:eek: :devil:
Only kidding. Nothing would happen because component is an analogue signal and dvi is digital so you'd simply get nowt.:rolleyes:
Dave
Don't think so, Digital video interface innit?
I may be talking out of my bumhole but I'm sure someone much cleverer than me will put me right if i am.:smashin:
barijohn
Established Member
Component can carry HD signals it just cannot work with HDCP protocols. So if you were sending an non HDCP signal the AMP will simply pass it through to your display.
It is a common thought that HDMI is the only way to transmit HD signals. Mainly because that is what the big studio bosses want us to think! :)
Why not just try it!
barijohn
Established Member
andrewtayloruk said:
Isn't DVI-I Analogue as well as digital?
Andrew
Yup your correct. It can carry both signals. Digital and Analogue.
Eddy Boy
Established Member
You could run a DVI-I to omponent lead but the res would need to be set to 480. the 1906 can pass hi-def via component hasn't got the bandwidth.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
