What would give the best PQ?
Discussion in 'Plasma TVs Forum' started by Lizzard, Dec 24, 2004.
  1. Lizzard
    Lizzard
    I am a bit confused in what to buy as i have a limited budget right now.
    I have narrowed it down to buy the Panny TH-50PHW6 without a separate scaler.
    Also i am torned between the TH-42PHD7 with a Lumagen Vision HDP scaler.
    The screen will be connected to a Denon 3910 player and a sat-receiver with component.
    Pricewise both choices are the same almost.
    As i am interested in getting the best PQ i can achieve, i am asking you what would give me the best picture quality of these two?
    If i go the 50" route i was thinking of adding a scaler later on when budget allows.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    For dvd I think the difference will be very small the denon is a good player. The difference would be on sky but I would go for the bigger 50" option. 8" is alot I have the panny 42" and another 8" on that would make it huge.
