What would be the best option!!!
Discussion in 'Video Streaming Boxes & Services' started by dan1el, Jun 5, 2008.
  1. dan1el
    dan1el
    Apr 20, 2008
    16
    I am looking for a media player/streamer which will do the following:
    1. Play mpg, wmv and Divx also WMA
    2. Must be able to connect a external USB 1tb western digital HD and play files from that.
    3. Have a nice user interface, would also like it to have thumbnail image view, (like media center)
    Also a few other things would be nice if it was HD with HDMI port.
    Built in wifi, maybe access to some online services!!
    If anybody knows of anything out there (other than the PCH) I would thank you for some advice.
  2. Gadgetcity
    Gadgetcity
    Apr 2, 2008
    850
    43
    Christchurch, NZ
    +149
    I use a PS3 to play avi, vob, mpg, wmv xvid and Divx also WMA WAV and MP3.
    It has a 320GB internal drive and 1TB Samsung external USB.
    It plays CDs, DVDs and Bluray and anything streamed from my PC using TVersity.
    It has HDMI, component, and RGB video.
    It has optical out.
    Don't know if that is suitable for any of your needs?
  3. dan1el
    dan1el
    Apr 20, 2008
    16
    Hi thanks for the reply, I didnt really want to get a playstion or xbox, I was really looking for a media streamer/player.
    Again Thanks.
  4. Gadgetcity
    Gadgetcity
    Apr 2, 2008
    850
    43
    Christchurch, NZ
    +149
    I'm not 100% sure what you want to use this for. Maybe something like a Popcorn Hour A-100 would do the trick?
  5. dan1el
    dan1el
    Apr 20, 2008
    16
    Yes I have tried the popcorh hour, really didnt get on with this. I was really looking for something with a nice GUI, The dlink DSM-330 looked spot in terms of nice GUI good price, but it doesnt suppot external hdd and as far as I can tell wont play mpeg files. I want the girlfriend to be able to use what ever i get, so nice and simple is the way foward..
    Thanks for the quick reply
  6. Gadgetcity
    Gadgetcity
    Apr 2, 2008
    850
    43
    Christchurch, NZ
    +149
    The dlink is not what you want - it is quite limited and it only plays stuff from a divx server running on a PC.
    Not sure what else to offer. I have the same girlfriend problem. She has always watched video on the main PC or laptop even when I've had video streamers, HTPCs and even a divx DVD player on the main TV. She does finally use the PS3 - but only for DVDs! :suicide:
    Good luck with your hunt. New stuff is coming out all the time.
  7. dan1el
    dan1el
    Apr 20, 2008
    16
    Thanks for you advice, I will kepp looking and if i do find anything then i will post my findings on here. If anybody else should come across anything close to my requirments then please let me know.
    Thanks Daniel
  8. DavidT
    DavidT
    Oct 30, 2001
    2,490
    +257
    How about the Netgear EVA8000.
    It supports virtually every video and audio file, has USB ports for an external HD, supports HD with HDMI connection, has wireless and a reasonable GUI.
    David
  9. dan1el
    dan1el
    Apr 20, 2008
    16
    Thanks David, i will look into that option
  10. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,163
    48
    +56
    I have the new TViX M-7000A then I added an optional 1TB internal Hdd it has USB connect to your PC for fast transfer. Can also connect to your network via wireless or ethernet. Also has two slots for external usb connections.
    Please full ISO rips of SD discs (around 8gb each) its working fine. Has the full functionality of the original discs.
  11. m47een
    m47een
    May 8, 2006
    28
    3
    Netgear EVA8000, should do the trick :thumbsup:
  12. dan1el
    dan1el
    Apr 20, 2008
    16
    Thanks for the advice, but I have to say I think this is alot of money.
  13. dan1el
    dan1el
    Apr 20, 2008
    16
    Just placed my order for A netgear EVA8000 Seems to be the best option for me, and with the latest firmware updates most people seem happy with it.
    Anyways I will let you know how I get on!!!
    Thanks for all your help.
  14. dan1el
    dan1el
    Apr 20, 2008
    16
    Ok Its turned up!, I have just had a play with it and it seems to do everything I need it to :thumbsup: Thanks for your advice chaps.:clap:
    Now I have to work out how to get my blue ray films to my nas drive and get the EVA to play them!!!!
    Thanks again.
    Daniel
