what wireless you got?
Discussion in 'General Video Gaming Chat' started by Hunterm8, Jan 18, 2004.
  1. Hunterm8
    Hunterm8
    Mar 5, 2003
    115
    16
    Leicester
    Hi i am going to go wireless on my xbox! using a wireless router hard wired to my pc and my x-box wireless using a wireless ethernet bridge.
    Could people who use this type of connection tell me what router/wireless bridge they are using and how they rate it?
    cheers all
  2. DJW
    DJW
    Aug 29, 2002
    965
    16
    D-Link is spot on !!! No dropped sessions in over 500 hrs of use, using Pipex ADSL
    Before this I used Belkin with NTL, which was good. But when I moved to ADSL it would not stay connected for more than 3 mins. Found to be a firmware prob. Downloaded latest fix , which when applied shagged the router. I went through 3 replacements before giving up & moving to D-Link.
    Neighbour has NetGear, which although cheap seems to have limited range.
    Most important thing I have found is going for the all in one modem/router/wireless makes life a hell of a lot easier & drastically reduces the chance of dropouts.
  3. pepsi
    pepsi
    Jan 12, 2004
    75
    Dundee
    +9
    Use Buffalo 54G. Works with no probs for all normal stuff.
    Was very good value for money.
    Pepsi.
  4. colesy
    colesy
    Dec 28, 2001
    721
    +16
    I used to use a Linksys befw11s4 router but had a occasional problem on xbox pgr2 (and only pgr 2 though) I have since upgraded to a D-Link 614+ and the pGR2 problem has gone.
    I do not know of any issues with any manufacturers wireless bridge, so you should be safe there.
    My D-Link 614+ has a big xbox live compatible logo on the front of the box.
    Check out a list of xbox live compatible routers on the USA and UK Live websites because the information differs slighty.
  5. Malone
    Malone
    Mar 12, 2001
    1,857
    Ilkeston,Derby
    +71
    Ere Ere I wonder? I've got the BEFW11S4 and a WET11 bridge all games are fine but when I play PGR2 I cant be in the same room as Typhoon ( probably cos he smells;) :D ) every time he tries to connect he comes in and then disappears and vice versa if I try to connect a game he is hosting, although others can accept him, and join any game he is hosting. Strange hummmm.
    Matt
    Not sure the point of my post but I just felt like giving me digits a work out.:D
  6. colesy
    colesy
    Dec 28, 2001
    721
    +16
    HERE is the one I have now Manic. Works a treat.
