What will I get with............
T
tomsenior9999
Hi I`m a newbie to all of this so I`m after a few pointers.
These are the bits of hardware my budget can afford me.
HTPC with a SkyStar2 Card
An 80 CM Gibertini Dish (see below for specs)
Size: 75 x 80 cm
Illumination Efficiency 69%
Gain @ 10,95 Ghz (dB): 36
Cross polarisation on axis (dB): 25
First side lobe (dB): 22
Noise temperature @ 30° elevation(K): 46
F/D radio:0.66
Beam width @ 3dB (deg): 2.6
Elevation angle range (deg): 0 - 80
Offset pointing angle (deg): 21.3
Mast clamp: 30 - 90 mm
Wind pressure @ 120 km/h: 42 kg
Operating temperature range: -30°C +70°C
Humidity: up to 100% condensed
Still undecided on best way to go with LNB Etc.
I live just outside Grantham UK. I don`t want to upset anyone so I`m looking at keeping my dish setup as small as possible. Could someone tell me the best way to setup my gear and what I should expect to recieve. Cheers for all your help
Tom
fernandez
There's a list of satellites viewable in the UK and the dish size required here
http://www.satellites.co.uk/satellite/archive/t-4386.html
Channels available, the encryption used, projected footprint etc. can be found by checking each satellite here
http://www.satcodx.com/eng/
Generally speaking go for an LNB with the lowest noise figure
Helpful info here
http://www.satcure.co.uk/tech/invacom.htm
Lots of softcam files available on the net to enable you to view encrypted channels
http://www.skystar.org/
Chris Muriel
[/url]
It's a shame that the satellite equipment industry has moved to the lowest common denominator in that people are forced to select LNBs by NF.
For digital satellite reception (DVB-S or DVB-S2) what really matters as much as, if not more than, NF is local oscillator stability and phase noise.
Unfortunately LNB makers and marketers went for the low hanging fruit of NF because it's much easier and quicker to measure than LO stability or phase noise; anyone involved in modern RF communications design at the system-block level knows this - but how can Joe Public be expected to ?
Very few LNBs have meaningful specifications for the above - unless you buy a $200 Norsat or similar PLL-controlled LNB.
End of (slightly techie) rant ...
Chris Muriel, Manchester
