What will I gain with a high quality component cable?
Discussion in 'Cables & Switches' started by Funkybase, Dec 23, 2004.
  1. Funkybase
    Funkybase
    Jul 21, 2004
    69
    I''ve recently bought a new DVD player Denon DVD-2910 and contected it to my 42" Viera. It's connected through a pretty cheap component cable, apporox £40 for 5 meters. What do I gain by changing to a more exclusive and expensive cable?
    Thanks!
  2. stebbo
    stebbo
    Nov 28, 2003
    174
    16
    Basingstoke Hanmpshire
    More than likely you will end up with a lighter wallet and a feeling of why did I bother.
  3. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    If you're thinking of changing cables then look to Mark Grant cables on this forum. (I only recommend these because I've recently bought a Co-ax cable from him and i'm impressed with the build quality) TV Cables also seem to be well thought of.
    I do agree with Stuart though. Throwing money at cables can often end in tears. GOOD cables are very important, the problem is expensive doesn't always mean good.
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Agreed. Cables are important but they are not miracle products. I recently upgraded from some cheap component cables to Mark Grant ones. The picture quality improvements were even noticed by my wife.
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,035
    +2,980
    I got the same component cable as the Mark Grant ones from Bluejeancable.com. It is definitely worth it but, I don't see spending anymore money.
    It only cost £25 for a 1.2m cable.
  6. CfP
    CfP
    Funkybase,
    If you're current cabling is 75Ohms and is being used for component connection (ie: 3 cables for video, not 1) then you're probably already getting 80% quality of the possible picture.
    The steps up from here are limited by your wallet and, as has been noted already, may not warrant the cash outlay.
    Decide what you REALLY want to spend, find the brands in that range and see if you can see them in action. If you like what u see, buy it. Otherwise, save your bikies for other component area upgrades.
    CfP
