what watts can my eltax take ?
Discussion in 'Home Cinema Speakers' started by jtfab75, Aug 3, 2004.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    still looking for an amp for my eltax ht2 speakers,looking at details for amp i see they give out the wattage.
    what is the maximum wattage can my speakers take ?
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    It should say on the back of the speakers. It does on the back of my HT2 bipolars. I wouldnt take to much notice of it as you would hardly run close to the limits of the speakers most of the time. Just dont buy an amp with over 50% more power than the speakers are rated at and IMHO you should have no problems unless you plan to run them at very high volumes for a long time eg disco :D
    How much are you wanting to spean on the amp and what are you looking at?
    :devil:
  3. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    i'm looking to spend no more then £150.i'm thinking of buying either a sony str de485 or yamaha htr 5630.i've seen a sherwood rvd8090rds i've seen for sale.
    this will be my first amp,so its all very scary .
    my speakers can take up to 60w.so will 100 w be ok ?
  4. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
