What Watt
Discussion in 'Home Cinema Speakers' started by jm1, Feb 15, 2003.
  1. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    Could I connect speakers with the following specs into receiver giving out 65w per channel, or should the speakers be a higher wattage than the receiver? Could this damage the speakers?
    Satellites
    Power Handling: 60 watts
    Nominal Impedance: 8 ohms
    Frequency Response: 80-20000Hz
    Centre Channel
    Power Handling: 90 watts
    jm1.
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    I think that would be pretty safe.
    The speakers are 8ohms and small, that means you don't need that much power.
    But when you say 65watts, how are those measured?
    4 or 8 ohm? How much THD?
    Try it out, and if your amp gets very hot, you know what to do.;)
  3. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
    The receiver is a yamaha HTR-5540, and in the manual it says the THD is 0.06%,20 Hz- 20Hz, 8ohms.
  4. jm1
    jm1
    Feb 9, 2003
    371
    28
    +90
