what wall bracket
Discussion in 'Home Cinema Buying & Building' started by philinman, Jan 3, 2004.
  1. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    Well i am in the process of getting jl to match a price on 504
    when they do i will be ordering it whats the best type of wall bracket to get i want a tilt type any ideas when be great as there is loads avaiable :p
  2. bobbypunk
    bobbypunk
    vogels wall bracket 15 degree tilt £350
  3. akerman
    akerman
    I don't get it.. howcome wallbrackets, which should be fairly simple in costruction, cost so much? £350, that's just ridicoulous to my ears :))
  4. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    cool i will look at that as well then
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  6. philinman
    philinman
    Jul 6, 2002
    406
    shropshire
    +4
    i am going to mounty it above my fire place i was oing to get the tilt one in case i needed it.
    :confused:
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
