What Video Cable for my LCD projector.
Discussion in 'Cables & Switches' started by noahstout, Jul 16, 2004.
  1. noahstout
    noahstout
    I just got the Epson 715c LCD projector and want to hook it up to my xbox (dvd). The Epson has regular RCA jacks, S-video, and a computer monitor jack. I'm pretty sure I should just use the RCA video jack for connecting up the xbox. The thing is, I'm wondering if the kind of RCA cable I use will do well. Will the length of the cable affect it? I'm considering getting like a 35' or 50' cable so I can have the xbox and the projector at different ends of my living room. :clown: Will a cable of that length have any noticeable delay? I've found some cable of that length on the internet for like $10-$15, that says its for high resolution and dvd connections and stuff (it says its professional grade with gold plated rca connectors and says its 75 ohm).
    Does anyone have any suggestions.
    thanks,
    ns
