What upgrade from ios11?
johnniehec
Hi my iPhone 7 is still on iOS 11, what’s the upgrade path? To 12, to 13, 14 or can I go as far as 13 or will I need to go straight to latest 14 ? If straight to 14 are there any pitfalls? Will it take ages is it likely to fail? Any advice appreciated
Thank you
John.
hippo99
You can’t pick & choose. It’ll just update to the latest supported version for your phone.
Settings>General>Software update & that will show you which version you will update to.
MaryWhitehouse
Yup should take you straight to iOS 14.0.1 and then a LOT of app updates. Make sure it’s on a charger and you’ve got plenty of time. Some older apps may not update.
