Question What type of Ethernet cable for skyq mini connections
Discussion in 'Sky Digital TV Forum' started by silverpuma, Dec 27, 2017.
  1. silverpuma
    silverpuma
    Oct 30, 2007
    545
    Northern Ireland UK
    +16
    Hi all, I need some advice, please. I have 2 Virgin V6 boxes that I have 2 cat5e cables running from my Router to these boxes so I don't use the wifi connections. I am joining SkyQ in mid-January and am adding an extra skyQ mini box to my set up.
    So I will now have 1 x SkyQ 2TB box and 2 skyQ mini boxes. I need to add another ethernet cable for this extra TV/Mini box.
    To my first question......Do all my ethernet cables attach from my Router to my 3 SkyQ boxes? So I will have 3 cables leaving my Router to my 3 skyQ boxes? Is this how they are connected?
    Secondly, is cat5e cable ok to use to this new TV/Mini box? Like this one for example.....? Since my other 2 cables are cat5e could I use a cable like the one I linked to but a cat6 or is it better not to mix cat5 and cat6?
    Thanks in advance for any help offered and for your patience with these basic questions....:)
  2. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    You can connect the boxes via Ethernet or WiFi or a mixture of both.
    I have my main Q box wired, 1x Mini wired and the second Mini is on WiFi.
    The nic on the Q system is only T100 so even Cat5 is fine. Don’t see any issue in mixing though.
  3. silverpuma
    silverpuma
    Oct 30, 2007
    545
    Northern Ireland UK
    +16
    Thanks Steveu30, just to check, do the ethernet cable on your 2 wired boxes both go back to your router? Or does the mini connect via ethernet to the main Q box? I'm just trying to figure out how these boxes connect via ethernet.
  4. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    Everything plugs into the router
  5. silverpuma
    silverpuma
    Oct 30, 2007
    545
    Northern Ireland UK
    +16
    Aaah....thanks all clear now!
  6. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,320
    +1,278
    And if you run out of ports on your router you can always buy a small switch.
  7. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    Exactly what I had to do, although I now need a bigger/second switch! [emoji23]
  8. silverpuma
    silverpuma
    Oct 30, 2007
    545
    Northern Ireland UK
    +16
    Thanks for all the help........... it's appreciated!
