What Type of Disks are Best to Use?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Fortesque, Dec 18, 2006.
  1. Fortesque
    Fortesque
    Nov 7, 2006
    63
    I have just ordered a Panasonic EX75. This gives me a choice of DVD-R, DVD-RW, DVD+R, DVD+RW or DVD-RAM disks. Obviously the RW & RAM disks allow me to re-record on them which will generally be useful to me. Which disks are best to use for:
    a) Write once.
    b) Write many times.
    ....and why?
  2. Cheekster
    Cheekster
    Mar 10, 2002
    1,163
    63
    Oxfordshire
    +195
    For write once I would recommend DVD-R, anything using the excellent Ritek dye. Why? Because you'll find these discs are most compatible with the vast majority of dvd players. This means they "should" work on any friends/family members players should you wish to lend them out.
    Write many times, I'd suggest DVD-RAM as it has benefits including chasing playback which basically means if you were recording a footie match and came home half way through it, you could start watching from the beginning whilst it continues to record the rest of the match. Pretty neat, huh? :D
    Cheekster.
  3. ChainsawDude
    ChainsawDude
    May 6, 2006
    375
    28
    Basingstoke
    +29
    a) use DVD-Ram to copy to PC then author the DVD-R on your PC with the correct WSS flag
    b) use DVD-RAM, only format Pansonic records correctly.
    PS Posting assumes knowledge of the Panasonic WSS problem.
  4. Fortesque
    Fortesque
    Nov 7, 2006
    63
    What about the RW disks?
    Also what are the best speed DVD-RAM and other disks to get?
