What TV????
Discussion in 'What Is The Best TV For You?' started by GavMonk, Jul 27, 2018.
  1. GavMonk
    GavMonk
    Jul 27, 2018
    4
    Tavistock
    Hi, I need to get a new TV as my existing has now got awful screen burn, now looking for reasonably priced 49"(ish) LED. Was looking at either Panasonic TX-50DX700B or LG49SJ800V.
    TBH I do not know too much about modern TV's & reviews seem to rate them as very similar, so was after some thoughts or perhaps suggestions of better TV's in similar price range.
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,252
    +4,411
    Do you need wide viewing angles and can you fit 55" ?
    What is your budget and do you need to buy now?
  3. GavMonk
    GavMonk
    Jul 27, 2018
    4
    Tavistock
    Not particularly wide viewing angles, could probably just about do 55” but will be tight, budget is prob £650-£700 max & yes need to buy very soon
  4. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,210
  5. Dodgexander
    Dodgexander
    May 29, 2007
    15,252
    +4,411
    There's little value to be had at smaller screen sizes. Agreed the TV above is best value.
  6. GavMonk
    GavMonk
    Jul 27, 2018
    4
    Tavistock
    Thank you, but Unfortunately £700 is my absolute max
  7. Dodgexander
    Dodgexander
    May 29, 2007
    15,252
    +4,411
    Hisense 55U7A then I guess. 50" model isn't as good.
  8. GavMonk
    GavMonk
    Jul 27, 2018
    4
    Tavistock
    Ok I’ll have a look at that one, always looked at big brands previously, is Hisense a decent brand?? Sorry not big with TV technology
  9. Dodgexander
    Dodgexander
    May 29, 2007
    15,252
    +4,411
    Each brand makes good and bad. There aren't really any good value alternatives other than what's been mentioned right now.
