What TV
Discussion in 'TVs' started by Keithhampson, Apr 22, 2005.
  1. Keithhampson
    Keithhampson
    Apr 22, 2005
    673
    +6
    Hello, I am looking for a new 32 inch tv, Panasonic TX32PM11 or a Phillips 32PW6518, which tv is best, I have seen a Panasonic in Comet which looks very good or would I be better with the Phillips.
    Which one is best and why
    Keith
  2. nig28
    nig28
    As a brand I would say Panasonic are more reliable than Phillips.
    Nigel
  3. Keithhampson
    Keithhampson
    Apr 22, 2005
    673
    +6
    no one can seem to tell me which is best, the Phillips is about £100 cheaper, can not get reviews on these tvs anywhere, money is not the problem, just want the best.
    thanks
  4. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    You can get a good picture from both of them, but the Phillips is harder to set up. Id go for the Panny because if you get a good one the picture is to die for with a good signal , and its easy to set up. Having said that all tvs built now can have Lemons ,even in the branded names, perhaps someone on here has that model and can be of more help.
