What TV will you be using with Sky HD
Discussion in 'Sky Digital TV Forum' started by Pebb, Mar 25, 2006.
  1. lovemovies
    lovemovies
    Mar 3, 2003
    231
    United Kingdom
    +5
    Panasonic 50" PHD8
  2. Thxfan
    Thxfan
    Sep 13, 2005
    107
    York
    +7
    Panasonic 42" PHD8
  3. rpreston
    rpreston
    Samsung LE40R51
  4. London Town
    London Town
    Jun 10, 2004
    2,326
    +209
    Sony 50" 3LCD
  5. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
    Optoma RD65 DLP 65' rear pro 1280x720
    Picture in signature. :)
  6. wuf810
    wuf810
    Phillips 37" PF9986 LCD
    just hope that it works as it has a DVI connector and no HDMI. Need a HDMI to DVI cable and I'm sure its gonna cause problems...
  7. paul_mowbray
    paul_mowbray
    wuf810 - should be fine, just get a hdmi-dvi converter dongle (like the dvi-vga ones you get with modern graphics cards) only problem you might have is if SkyHD requires hdcp and your dvi port doesn't support it.
  8. scharf_10
    scharf_10
    Jan 4, 2006
    851
    Near Dundee, Scotland
    +83
    LG 32LX2R - Really worried about the HDCP compatability issues though :(
  9. neil2k
    neil2k
    Oct 31, 2005
    369
    Norfolk
    +12
    Sony KDLV40A12u.:thumbsup:
  10. tony79
    tony79
    Jan 6, 2005
    1,172
    +88
    same here! Pity that we wont be eligable for a discount. You think they may do a offer for those who already own a bravia?
  11. shropsboy
    shropsboy
    Dec 27, 2004
    Huddersfield
    +10
    Tosh 37WLT58. Bought due to the amount of positive comments on this site! :)
  12. jcw1407
    jcw1407
    Feb 27, 2006
    40
    Hitachi 42PD6600 , seeing as no-one else is owning up to having one ;)
    James
  13. hutchys
    hutchys
    Feb 4, 2002
    142
    16
    Samsung SP46L6HX - 46" DLP RPTV HD-Ready:thumbsup:
  14. as
    as
    Aug 23, 2001
    302
    +8
    rd 65" dlp:thumbsup:
  15. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Screenplay 7205 with 92" fixed screen. Anybody who thinks quantity and quality are mutually exclusive, should see this.
  16. Stuall
    Stuall
    Jun 10, 2005
    52
    4
    11
    tosh 37wl56
  17. dfisher_uk
    dfisher_uk
    Nov 16, 2005
    459
    28
    Edinburgh
    +40
    [​IMG]
    Philips PF9830 ;)
    Can't wait!
  18. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,398
    Manchester
    +6,136
    Panny TX32LXD500
  19. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    Me too - and don't be - worst case is all you need to do is swap the HDMI and DVI connections over isn't it? Also can't wait! :clap: :clap: :clap: :clap: :clap:
  20. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
    I still need to get a TV for mine :D
  21. Qwelldrin
    Qwelldrin
    Mar 26, 2006
    15
    Hope all you guys now the SKY standards and what the Audio output will be I dont and untill somebody form SKY HD tells me You may have a beautifull picture but with no Audio. LET THEM TELL US what they are providing before you order it. BE carfull here HD is not just the Signal but also a Visual and audio change unless sky tell us different.
    Actually SKy HD have not released a connection standard for there unit. May I also say that HD is a resolution of screen and not a Conector Type HD ready can mean that a Screen is 720p 1080I and 1080P, none of these screens must have a HDMI connector. HDMI will carry audio as well as video so unless somebody from sky tells you that in your home entertainmet center you have optional audio outputs as well. Then you will also need a HDMI to Audio Splitter and converter, Audio channels being Digtal. Nobody in SKY has yet commented on if there Sky HD boxes are also HDCP complient. This would also mean that your current PLasma or LCD screen would not cater fro the encrytion of HDCP. SKY needs to make there standard clear before anyone should buy into the new HD system.
  22. sanderton
    sanderton
    Mar 31, 2005
    687
    Somerset
    +20
    Why have you posted the same (incorrect) post in four threads?
  23. Pebb
    Pebb
    Dec 29, 2005
    13,155
    Eastleigh
    +829
    You know HDMI carries audio aswell.
  24. Qwelldrin
    Qwelldrin
    Mar 26, 2006
    15
    Hi Sanderton, Which part of the previous post do you consider incorrect?
  25. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Most of it, the parts that I could actually read anyway.
    Sky HAVE already said they will enforce HDCP, when decided by the content owner. Only about 14 months ago though, and it's been discussed at length since, so I can see how you might have missed that.
    It's also been well publicised that the box has analog and optical audio out, quite separately from the HDMI (and indeed component) connections
    HD Ready DOES mean that the TV will support HDMI (or DVI) with HDCP.
    What else did you say that's not wrong?
  26. Qwelldrin
    Qwelldrin
    Mar 26, 2006
    15
    HD Ready actually only means that the Display can dislay 720p 1080I or 1080p and not the connection this is a
    definition of a Resolution standard, HDMI is a cabeling standard being adopted by Europe. HDCP is a encryption standard being introduced to ensure that equipment ie DVD to HDTV passes a encrypted code to ensure that the played DVD is not being copied!
  27. splnter
    splnter
    Oct 20, 2003
    602
    Basingstoke. Hampshire
    +51
    Pioneer 435XDE + sony hs60.. 8 foot picture. :)
  28. tony79
    tony79
    Jan 6, 2005
    1,172
    +88
    actually for a set to carry the "HD ready" logo the folowing must apply
    1. Display, display engine
    a. The minimum native resolution of the display (e.g. LCD, PDP) or display engine (e.g. DLP) is 720 physical lines in wide aspect ratio.
    2. Video Interfaces
    a. The display device accepts HD input via:
    i. Analog YPbPr “HD ready” displays support analog YPbPr as a HD input format to allow full compatibility with today's HD video sources in the market. Support of the YPbPr signal should be through common industry standard connectors directly on the HD ready display or through an adaptor easily accessible to the consumer; and:
    b. DVI or HDMI HD capable inputs accept the following HD video formats:
    i. 1280x720 @ 50 and 60Hz progressive (“720p”)
    ii. 1920x1080 @ 50 and 60Hz interlaced (“1080i”)
    c. The DVI or HDMI input supports copy protection (HDCP)
    The following technical references apply:
    DVI: DDWG, “DVI Visual Interface”, rev 1.0, Apr 2, 1999 as further qualified in EIA861B, “A DTV Profile for Uncompressed High Speed Digital Interfaces” May 2002, furthermore allowing both DVI-D and DVI-I connectors, requiring compliance to both 50 and 60Hz profiles, and requiring support for both 720p and 1080i video formats.
    HDMI: HDMI Licensing, LLC, “High-Definition Multimedia Interface”, rev.1.1, May 20, 2004
    HDCP: Intel, “High-Bandwidth Digital Content Protection System”, rev 1.1, June 9, 2003
    (NB: on DVI HDCP rev 1.0 will apply)
    YPbPr: EIA770.3-A, March 2000 <check pending on version of this specification>, with the notice that the connectors required may be available only through an adaptor.
    with regard to the audio I would assume that the optical output would allow the audio to be sent to an av reciever as it is at the moment with my sky+ box.
  29. KinkyAffro
    KinkyAffro
    Dec 13, 2005
    1,508
    63
    South Yorkshire
    +164
    Panasonic PX60
  30. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    We've already taken this to PM calmly, but nothing I said above contradicts this. Not sure what you were trying to point out? HDMI isn't just Europe either.
    And it doesn't sound like you know that HDMI & DVI video signals are identical? HDMI just adds audio & provides a smaller connector.
