What TV should I get for about £600?
Waynej
Our 32" Toshiba Widescreen CRT is pretty much knackered. We are able to spend the full amount in COMET that we spent on our TV originally. £569.99.
Ideally we'd like another 32" screen, though it may only be possible to get a 26". Though seeing as its for the living room, can I expect to find a 32" Plasma or similar for about the £600 mark.
Or are there any HD 720p Projectors from comet for around £600?
Eddy_mc
You have no hope in hell of finding a HD ready 32" plasma or lcd for £600, the best comet have for £600 or under is a 20" philips for £478, or for a little more than 600 a Samsung 26" for £650.
Eddy
neilmcl
If you really want a good replacement for your old CRT then you should look at the Sharp LC32P50E, can be got for around £699, maybe cheaper if you look around. The 26" versions will be cheaper still. As Eddy saisy you won't get a current plasma at 32", although I'm sure Hitachi used to do one.
Waynej
Yeh, I'm sure it's possible to find one online, but the chances of comet not charging rip-off prices. well you know what i mean :suicide:
That Samsung 27" that play had for £550, I find that quite tempting; no sign of it on comet though
mattg
depending on how long you have had the tv, you may be able to claim a full refund rather than a replacement under the sales of goods act. This probably wouldn't be possible if it is more than 12months old though.
comet would have to prove the fault was not present at the point of sales which is pretty tricky for them.
This would free up the cash to buy from cheaper online retailers. For example waratah.co.uk sell the 26" samsung with built in digi box for £610 delivered next day (if in stock). If you already have a digi box I think it comes in about £550.
Waynej
Sounds interesting. I'll have to have a look at the paper work on it. I know there is 3 years cover on it. But We are either just under or over the intitial 12mths.
will have a look and let u know cheers
:smashin:
neilmcl
You're only likely due a full refund if the fault was discovered within a "reasonable period" after purchase, ie, something like 28 days, after this only a repair or replacement can be offered.
