What to use?
Discussion in 'Cables & Switches' started by guvvie, Sep 6, 2005.
  1. guvvie
    guvvie
    Aug 24, 2005
    733
    46
    +136
    I was going to buy a J S Technology RGB scart to YUV to connect my sky+ to my av reciever, when I found this. Why is there £135 price difference when they both claim to do the same thing. Any help would be appreciated.
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    That is a very good question.
    It depends what the cable hides in the shell of the scart.
    I may have one of these in my loft actually... I never read the packet and assume it was scart-RGB with no syncs (which I needed).
    I believe there is a way to passively convert the video, but if this is the case, It cannot be of any quality for projectors or plasmas etc.
    The benifit of spening the £130 more is to have an active box, with active circuits, which does not play with impedances to gain the correct levels of video on the outputs, which can lead to a noisy, weak signal.
    This is based on theory, not practice because I've never used a pasive devise for transcoding.
    I may dig out my cable today or tomorrow and see what this is about...
    Gareth.
  3. MPK
    MPK
    Nov 26, 2004
    479
    London
    +8
    Interesting. I know there is a way to convert RGB Scart to Component simply through a cable and there are several threads in this forum. However, if I remember correctly, in addition to the 3 YUV connections there is a fourth one needed that provides the sync signal to the normal composite input. Also, inside the scart plug there needs to be some re-wiring done. I don't think there is a way of achieving this with only three YUV connections and am pretty sure this cable won't work.
  4. guvvie
    guvvie
    Aug 24, 2005
    733
    46
    +136
    If you currently use a active box to convert the signals I would appreciate it if you could try out the cable that you have in the loft, then let me know what the picture is like after being passively converted. Don't want to waste £135 on something that only makes a neglidgable difference.
    thanks
  5. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I dont use a converter at home, but I am a broadcast hardware/systems engineer in Soho, and transcoding is as common where I work as post-it notes and paperclips in an office!
    I'll dig it out and confirm if it is what I think it is (i'll cut it open and take a look aswell).
    If there are any interesting findings, I'll post a photo aswel!
    I'll keep you posted.
    Gareth.
