what to upgrade 1st?????
Discussion in 'AV Receivers & Amplifiers' started by Daddy k, Oct 27, 2005.
  1. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    hi guys im wanting to slowly upgrade my setup.
    you can see my current setup in my sig at the bottom.
    not sure if this is the right place to post but hey ill give it a go.
    so what would you recomend i upgrade first going on a sub £400 budget at this point??
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Its difficult to suggest anything, except maybe save. You have a cheaper system so obviusly your looking to get the next level up, and altough recomending the lower end full sized recievers from the likes of denon and yamaha, i doubt the improvement would be enough to stave off any further need to upgrade in the near future.
    You could go with the yamaha av set 57 , which includes the entry level amp and some decent starter speakers, all this for under £200, but if you want better than that your gonna have to put more money in. Maybe with a little saving
    http://ws3.richersounds.com/showpro...X5.1-SIL&SID=3fb5c28e44de9491280831a014e0f464 with this http://ws3.richersounds.com/showproduct.php?cda=showproduct&pid=CAMB-AZUR540R-SIL .
  3. heavenly93
    heavenly93
    The Audio Azur 540R is worth saving for.
    I personaly would not first get a sub. Amp, speakers and then a sub.
  4. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    mmm yes that does look good!
    what would be the cheapest and best option with video switching & upscaling?
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    If you mean upconversion not upscalling then I think the entire yamaha x57 range has both, although the 657 (£300+) is probably the best one to start at and demo against a 757 (if you can one :p) . All amps have video switching though, just the upconversion is a bit newer, upscaling is very new and only coming out now on the higher end models.
