What To Replace My 50" Pioneer PDP-LX508D KURO Plasma With?
S R S
Since 2008 my Pioneer plasma has been faultless, and continues to provide stunning pictures.
I am just starting to look at replacements and would appreciate your input as to what is on the market currently that would improve on the picture quality/resolution.
I have a full 5.1 setup (the LX508D being basically a monitor), so the picture quality is my only driver. Not too bothered about the OS either, as I am used to using Roku...
Size-wise, probably 65" but might stretch to 77".
Is it worth changing now, or wait the the Pioneer expires?
Many thanks.
SRS
tvdavid
replaced mine with 55 inch CX the pio still has the better blacks though the CX has better HDR video.
I still use mine though in the other room.
martin 39
Definitely go oled and vo 65 or bigger i changed my lx5090 for a 55 panasonic and within 3 yrs gone 65 i should of done that from the off.
AventadorSVJ
I replaced my fantastic Pioneer KRP-500a with a LG CX77 and have been impressed.
Once I got over the motion issues on the OLED screen, I feel happy and simply put, you get used to the size difference very quickly.
I recommend the biggest size you can afford/accommodate.
