What to replace a 9800 pro with
Discussion in 'Microsoft Windows' started by dUnKle, Sep 7, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,154
    +2,166
    My HCPC has a 9800 pro graphics card - now my other halfs PC is in need of an upgrade but just enough for her to use WinXP - so I intend to put the 9800 in her machine and have a slight upgrade in the HCPC
    For around £100 what card (AGP) would be worth the swap
  2. Rambles
    Rambles
    Jul 14, 2004
    8,097
    UK
    +1,069
    Something from the Geforce 6 series with Pure Video support, the 6600Gt is good, but a bit over budget. Recent discussion on here suggests that the fanless 6200 for about £50 will do the job.
  3. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    the 9800PRO is more powerfull than a 6200, if you had PCI-E you could of got a x800GT, but trd and find a cheap 6600GT or ATI Radeon X700 PRO
  4. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    I would keep the 9800 and buy a cheap card for your other halfs PC nvidia 6200 for about £50.
  5. DaveP
    DaveP
    eBuyer have a 6600GT on offer for less than a ton.
    It has a fan though, but you could change that later if needed.
    Dave
  6. JayList
    JayList
    I wouldn't spend to much on a non PCI card now. Although I remember reading their was a dual PCI/aGP card. This way you could buy now and swich when you moved to PCI express.
    Well worth it imho.
