what to pair with B&W 602 as fronts??
Discussion in 'Home Cinema Speakers' started by kiddi, Nov 12, 2003.
  1. kiddi
    kiddi
    I have the B&W 602 and plan to use them as fronts in my home cinema. What center speaker and background speakers would you recomend to use with them?
    PS: I live in Iceland and we don't have B&W here. Obviously they would be the first choice.:rolleyes:
  2. kiddi
    kiddi
    anyone??
  3. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    Have you tried second hand? look out for, LCR6, LCR600, CC6, LCR60 probably in that order of preference for centre, look out for other 600 series for rear if you can get as set of 603's move the 2's to rear all B&W 600 series 2 or 3 would be fine. An alternative may be some Solids HTM1's or Centrale for the rear, they are quite a good tonal match. Check out the B&W site for info.
    http://www.bwspeakers.com/downloadFile/speakerModel/done-_product_info_Solid_Series.pdf
