F
FlatScreenNewbi
Hi Everyone,
I need to tidy up the cables and as the TV cable will be going to a single socket which is on display, it's ugly so I am considering burying the cable in the wall, and replacing the socket plate with with a fused front plate and wiring the TV cable directly to this. Will this be OK?
The main concerns I have is, I have to cut off the plug. Is there anywhere where I can get a spare cable so I can avoid destroying the original mains cable?
Has anyone done the above? Did you reduce the fuse from 13AMP to 5AMP?
Thanks in advance
Thanks in advance
