What to do with PCMCA slot for TH37PE30B
Discussion in 'Plasma TVs Forum' started by Jason Burdett, Nov 17, 2004.
  1. Jason Burdett
    Jason Burdett
    Just received delivery of my long awaited plasma, and so far everthings great. I notice it has an SD card slot and a PCMCIA card slot. Now then, have any of you peeps got good ideas for what to use them for?.
    The reason I ask is that SD slot I know is for for camera pictures, but that doesn't suit me as I've just realised my camera has the xD type of memory!. Now I was wondering about buying a PCMCIA firewire/usb card card bus. I could then stick in an all in one memory card reader (usb) into the said PCMCIA card bus and read my favourite snaps from that? Or am I going about this in a completely wrong manner?
    Hope you can help
    Best Regards
    Jason
  2. blindlemon
    blindlemon
    The PCMCIA slot will accept a converter - eg. for CF (although not microdrives). I can't remember whether xD is supported, but it should be in the manual.
  3. Jason Burdett
    Jason Burdett
    thanks blindlemon. i will thoroughly check out the manual, but can't remember seeing anything re the newer xD specification of memory card. Jason
  4. swartzy
    swartzy
    Apr 16, 2001
    9,471
    Northern Ireland
    +687
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    To loosely quote the manual...
    Another point to note: Whilst the SD cards can be inserted and removed without powering off the TV, the TV has to be powered off when inserting the PCMCIA adaptor card for the other formats of memory. :lesson:
    S.
